I am attempting to upgrade an old Pi3 with MPD outputting to a "7.1 sound card" with a Pi 5 and a HifiBerry DAC 8+ hat. So far, I have been able to make sound, but not really get the hat configured so I can set up my file streamer or anything further.
aplay -L:
null
Discard all samples (playback) or generate zero samples (capture)
sysdefault
Default Audio Device
lavrate
Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Playback/recording through the PulseAudio sound server
hw:CARD=vc4hdmi0,DEV=0
vc4-hdmi-0, MAI PCM i2s-hifi-0
Direct hardware device without any conversions
plughw:CARD=vc4hdmi0,DEV=0
Hardware device with all software conversions
sysdefault:CARD=vc4hdmi0
hdmi:CARD=vc4hdmi0,DEV=0
HDMI Audio Output
dmix:CARD=vc4hdmi0,DEV=0
Direct sample mixing device
usbstream:CARD=vc4hdmi0
vc4-hdmi-0
USB Stream Output
hw:CARD=vc4hdmi1,DEV=0
vc4-hdmi-1, MAI PCM i2s-hifi-0
plughw:CARD=vc4hdmi1,DEV=0
sysdefault:CARD=vc4hdmi1
hdmi:CARD=vc4hdmi1,DEV=0
HDMI Audio Output
dmix:CARD=vc4hdmi1,DEV=0
usbstream:CARD=vc4hdmi1
vc4-hdmi-1
USB Stream Output
hw:CARD=sndrpihifiberry,DEV=0
snd_rpi_hifiberry_dac8x, HifiBerry DAC8x HiFi pcm5102a-hifi-0
plughw:CARD=sndrpihifiberry,DEV=0
sysdefault:CARD=sndrpihifiberry
dmix:CARD=sndrpihifiberry,DEV=0
usbstream:CARD=sndrpihifiberry
USB Stream Output
when I try to address any of the 8 outputs (HifiBerry says these are not stereo pairs, but individual channels), I just get errors like:
jay@raspberrypi:~ $ aplay -D sndrpihifiberry,DEV=0 --dump-hw-params /dev/zero
ALSA lib pcm.c:2666🙁snd_pcm_open_noupdate) Unknown PCM sndrpihifiberry,DEV=0
aplay: main:831: audio open error: No such file or directory
I know I'm being stupid, but I've been stuck here for months. . .
Thanks for any advice!
aplay -L:
null
sysdefault
lavrate
samplerate
speexrate
jack
oss
Open Sound System
pulse
speex
upmix
vdownmix
default
HDMI Audio Output
vc4-hdmi-0
USB Stream Output
HDMI Audio Output
vc4-hdmi-1
USB Stream Output
USB Stream Output
I wish i could help. I really love the idea of the dac8x pi5 combo. Super affordale with a ton of dsp potential. Out of curiosity, Have you tried the dac8x with moode?
Since I've not been able to address any of the 8 channels individually yet, no........
Thanks, though.
Thanks, though.
That's correct - there is no PCM device like that. The name should be e.g.Code:jay@raspberrypi:~ $ aplay -D sndrpihifiberry,DEV=0 --dump-hw-params /dev/zero ALSA lib pcm.c:2666snd_pcm_open_noupdate) Unknown PCM sndrpihifiberry,DEV=0
hw:sndrpihifiberry,DEV=0
, or as hinted in your aplay -L
output: hw:CARD=sndrpihifiberry,DEV=0
.Offtopic: I would recommend to use the
[CODE]
tag for the listings so that indentation is preserved and the message is readable. Thanks.Thank you! That does help:
Code:
jay@raspberrypi:~ $ aplay -D hw:CARD=sndrpihifiberry,DEV=0 --dump-hw-params /dev/zero
Playing raw data '/dev/zero' : Unsigned 8 bit, Rate 8000 Hz, Mono
HW Params of device "hw:CARD=sndrpihifiberry,DEV=0":
ACCESS: MMAP_INTERLEAVED RW_INTERLEAVED
FORMAT: S16_LE S24_LE S32_LE
SUBFORMAT: STD
SAMPLE_BITS: [16 32]
FRAME_BITS: [32 256]
CHANNELS: [2 8]
RATE: [8000 192000]
PERIOD_TIME: (5 8192000]
PERIOD_SIZE: [1 65536]
PERIOD_BYTES: [32 262144]
PERIODS: [2 131072]
BUFFER_TIME: (10 16384000]
BUFFER_SIZE: [2 131072]
BUFFER_BYTES: [32 524288]
TICK_TIME: ALL
aplay: set_params:1352: Sample format non available
Available formats:
[LIST]
[*]S16_LE
[*]S24_LE
[*]S32_LE
[/LIST]
