Rebuild Vienna Acoustics Bach
Hey guys, I have an older pair of Vienna Acoustics Bach floor speakers. I need to replace the drivers. I have called Vienna of NA and they say that the driver is not produced anymore. They replaced it with the new Bach Grand and the outer diameter of the driver is a little bit larger. Has anyone rebuilt a pair of these? What drivers are you using now? Thanks
Another option is wait for NOS or used but working units float up on ebay. It takes patience but worthwhile when you want to replace with original units and there is no other option. (Even re-coning/replacing the spider trap by a specialist etc will not have it match the identical measured specs of a NOS/original driver).
Yes, I'm subscribed.
If you have drivers that are blown, perhaps you are playing with amps and fried the voice coils you can have them rebuilt, perhaps ewven locally depending on where you are. Sometimes they have to replace the cone as well as it cant be seperated cleanly. Dont do it if thats the case. Your best bet is to watch ebay though...might take a while for the woofers to show up. I believe the vienna stuff is all proprietary with the clear cones and all that.
