My sub started to hum, I noticed that the female RCA terminal was loose and if i position it a certain way it would sound correct. repair should be a walk in a park, just remove the plate amp, solder or glue the RCA connector poof, job done.... until you noticed that the back side of the RCA connector is covered with a black plastic box
Why is there a need to enclose the backside of the RCA ?
Any ideas what to do next, should I remove the box ?
It is possible to install the RCA on an empty place of the plate. Drill. Install. Connect with shielded wire (twisted pair). But it's up to you 🙂
Quote - "why is there a need to enclose the backside of the RCA ? "
There could be several reasons -
1-to make sure the repair is carried out by the company--
2- the inside of the box is copper powdered lined for screening purposes -
3-circuit design exclusivity-
4-to stop either electric shock or static sensitive components exist (to stop you "zapping" them ) .
There could be more reasons --like the firmware module is inside but they certainly don't want you opening it --just look at the glue --which looks a bit cheaply done to me --very amateurish !
Sealing any air-leaks to prevent whistling through the RCA and/or front plate connectors.
I've seen it done on lots of equipment.
^^^^^ quite possible.
Those might not be plain RCA but some version soldered straight to a small PCB inside that box.
but ....
maybe the problem is not even a soldering one and you don´t really need access to the inside of the box.
The internal RCA contact which is a hollow tube with a slit on a side may very well have expanded and lost tension,you may close it somewhat with a thickish sewing needle.
That is done all the time with tube sockets.
Try it.
but ....
Try it.
