Repairing the Carlsbro powerline pro 2000 amp
Hy,
I am curently repairing a carlsbro powerline pro 2000 PA amp.
The problem is, that the left channel of it distords hardly.
I checked te preamp and input board and they are fine(I swaped the channels)
The issue is not in the main board, but it is in the driver board.I replaced all of the transistors on there, but it stil does not work.
If anybody has the schematic of this amp, I would realy apreciate if you post it!
Thanks, thousand times.
Carlsbro 2000
I have got one which i bought as a backup, they are pretty good amps. Problem i had was the output speakon connectors. chinese crap. Mine continually distorted on one channel,so what i did rather than replace new speakon sockets,which is a big job was to wire new speakon sockets from the binding posts. Job Done.
