Hi!
I would like to make a DOD compressor (optical). But I came across the fact that now the use of photoresistors (RoSH) is prohibited in the European Union.
Please tell me how you can replace the photoresistor with a photodiode or phototransistor. I couldn't find anything similar on the internet.
Thank you!
Thank you!
I don't think you can if the LDR is used as a controllable resistor. It might be possible to do something with FETs.
As far as I know, the use of cadmium sulfide LDRs is not forbidden, but selling equipment with such LDRs is, with some exceptions for vehicles, medical equipment and military equipment.
I think it's possible. Not a direct replacement of course. The only embarrassing thing is that I did not find a phototransistor with a dark resistance of about 1mΩ. In the datasheets I can not find graphs of changes in the collector-emitter resistance depending on the illumination. I would like to comply with ROCH. Maybe later I will make another version that can be used for commercial purposes.
You can try TLX9175J. But I still can't figure out what the resistances are in the open or dark state.
Interesting option. What worries me is the fact that it has a trigger LED current and a return LED current - if that means it has hysteresis, you probably can't use it. Then again, maybe it doesn't.
To confirm what Marcel said, these components are not interchangeable: a LDR is basically a light-controlled resistor, completely linear and symmetrical (in an ideal world, the reality is somewhat less shiny), but a phototransistor or photodiode is mostly is current control device: it is a light-programmable CCS.
In the saturation region, the semiconductors exhibit a LDR-like behaviour, but for a very limited range.
Fets have more symmetry and lineariity, but for a limited range.
There are now light-controlled FET/MOS devices, which should behave more like a LDR, but I have no experience with them, and I cannot tell you how well they perform in real life.
That said, the ban on these devices looks ridiculous considering the amount of active material present in the component: they are practically thin-film devices now, meaning problematic substances are present in the ng range at most.
The currenty available LDRs are ~cheap thin-film types, but they have poor linearity and power-handling. Good, relatively linear LDR's were made in the sixties-seventies by companies of the Philips group: the ORP12 for example.
They used a sintered process instead of a film (thin or thick), and were much better, but they were more expensive and use much larger amounts of theoretically hazardous material.
This has to been seen in perspective: lead batteries are still allowed, yet they contain huge amounts of lead.... go figure: ng against kg
Thank you!
This is just an approximation that such use is possible.
That's why I asked the question. Perhaps someone knows the correct option.
If you need a photoresistor, I have at least tens of them in my stock, if not hundreds. If you need one I can send you one ( or half a dozen) for free. Just PM me with your exact requirements, and I might have something suitable
This is a radical departure from the simple concept of directly using an LDR as part of a voltage divider for volume control, but it occurs to me you could use the output of a photodiode driven by an LED to modulate the tail current of a diff pair, and hence its gain. An old dinosaur IC like the RCA/Intersil CA3080 might also be useful in this respect.
True, but he´s trying to clone a specific DOD pedal. which happens to use LED/LDR attenuator in the NFB path.
LDR is floating so no "shunt to ground" approach woks.
But thanks God kind Elvee saved the day 🙂
Thank you! I read about it.There are now light-controlled FET/MOS devices
Thank you so much! I live in Bulgaria. Photoresistors are still available in the store. So I can make a device for myself. But I would like to try to make this device so that it could be sold. And in this case, it makes sense to look for other replacement options.If you need a photoresistor, I have at least tens of them in my stock
Most likely it won't fit. But the idea is interesting. I'll think about it.use the output of a photodiode driven by an LED to modulate the tail current of a diff pair, and hence its gain
If you want to make a prototype pedal, build it with the LDR generously offered by Elvee.
If you want to build a few, and try to sell them at a Boutique/Home level, go and grab what´s available locally.
IF it becomes a resounding success and tens or hundreds are needed (hey! ... why not?), then the kind Alibaba guys will supply you as many as you want.
Personally I fully agree with keeping contamination out of land and water, but Politicians as usual have no clue and don´t care, and contradict themselves in a GROSS way.
As in: lead is bad, sure, lead in solder IS a factor ... but they exempted CAR INDUSTRY 😱 from that (obviously for $$$$$$$ reasons) .... so they forbid a couple Tons and allow THOUSANDS??? WTF???
By the same token, Cadmium was once popular for chassis plating (I still remember 70´s and 80´s typical Japanese multi-hued yellowish chassis) which admittedly aggregated up to Tons into dumpsters .... but a CDS cell uses an atoms thin layer covering a 5 mm disk, a few MICRO grams at most .... many orders of magnitude difference.
Oh well.
Oh well.
- Design & Build
- Parts
- Replace photoresistor with phototransistor or photodiode
