Replacement and Adaptation of the JBL ES250P Subwoofer Amplifier Module with Full Protection Integration and Thermal Improvements
Hello. This is my first post here and I hope you like it. After taking my JBL ES250P subwoofer (12", 250W, 4 Ohm) to two authorized JBL technical support centers, it was found that the amplification board was defective and could not be repaired or spare parts were available. So I decided to try to recover this excellent subwoofer myself and it worked very well. I will share here what was done.
🎯 Objective​
To replace the faulty amplifier board of the JBL ES250P subwoofer with a new board based on the IRS2092S, ensuring the retention of all original protection features and optimizing thermal dissipation for safe operation within the subwoofer's sealed enclosure, without forced ventilation.
🧱 Original Configuration​
  • The JBL ES250P comprises three main boards:
    1. Preamplifier, Filters and Limiter Board: Handles signal input, control, and crossover functions.
    2. Power Supply and Protection Board : Manages rectification and filtering with capacitors.
    3. Amplifier Board (see below): The original board was damaged beyond repair and unavailable for replacement.
🔁 Amplifier Board Replacement​
  • Chosen Replacement: Chinese L30D Module (There are already some discussion forums about this amplifier here at diyAudio)
    • Based on the IRS2092S Class D amplifier IC.
    • Hybrid architecture combining elements from Infineon's designs:
      • IRAUDAMP7S: Manages input and control (pins 1–6 of IRS2092S) and +15V Vcc power supply (pin 12 of IRS2092S).
      • IRAUDAMP9: Handles output stage with totem-pole BJT + IRFB4227 MOSFETs (pins 7–11, 13-16 of IRS2092S).
🔥 Initial Thermal Challenges Identified in L30D board​
1. Vcc Power Supply (+15V)​
  • Originally implemented using (see IRAUDAMP7S):
    • R114 (1 kΩ / 5 W)
    • Z102 15 V Zener Diode
    • Q105 TIP31 configured as an emitter follower
  • Resulted in excessive power dissipation (~3.6 W) in R114, leading to significant heating.
2. Capacitors CP5 (bypass filter for Vcc supply) and CP6 (bootstrap)​
  • Electrolytic capacitors rated at 47 µF / 63 V (as per the Chinese PCB version).
  • Experienced considerable heating due to high-frequency ripple and 400 kHz switching cycles.
✅ Implemented Modifications for Thermal Optimization​
🔋 Vcc Power Supply Replacement​
  • Removed the original TIP31 + Zener + R114 configuration.
  • Introduced a XL7015 DC-DC Buck Converter Module:
    • Input: −75 V
    • Output: −60 V (=15 V relative to −75 V)
    • Provides ample current to power the IRS2092S and totem-pole stages with minimal heat generation.
🔧 Capacitor Upgrades for CP5 and CP6​
  • CP5:
    • Replaced with a 10 µF / 25 V Tantalum Capacitor.
    • Added a 1 µF / 50 V Ceramic Capacitor in parallel.
  • CP6:
    • Replaced with a 22 µF / 25 V Tantalum Capacitor.
Outcome: Eliminated noticeable heating in these components.
🧠 Integration with JBL's Original Protection System​
🔐 Retained Active Protections:​
  • Temperature Monitoring: Sensor relocated to the new L30D module's heatsink.
  • DC Output Detection: Continuously monitored through original circuitry.
  • Output Short-Circuit Protection: Ensured through original circuitry.
  • Idle Timeout: Activates protection after 10 minutes of inactivity through original circuitry.
🛑 IRS2092S Shutdown Implementation (Extern SD):​
  • The original JBL protection circuit outputs +15 V upon fault detection.
  • This signal directly controls a transistor (2N5551) circuit that pulls the SD (Shutdown) pin of the IRS2092S to -5V, effectively disabling the output amplifier during fault conditions.
🔴 Protection Indicator LED:​
  • A red LED was integrated into the protection circuit in case of SD (external or internal), using a BC557 transistor.
  • Provides a clear visual indication when the system enters protection mode.
💡 Physical and Thermal Customizations​
  • LED Placement:
    • Utilized two existing mounting holes from the original JBL amplifier PCB:
      • Installed the L30D's original green LED (indicating active PWM) in one hole.
      • Installed the new red protection LED in the other hole.
  • Mounting the L30D Module:
    • Drilled two new holes in the JBL's metal backplate to secure the L30D module.
    • Mounted the module via its heatsink, utilizing two pre-existing holes in the heatsink.
    • Applied thermal paste between the L30D heatsink and the JBL metal plate to enhance heat dissipation.
✅ Final Outcome​
  • Successfully restored the JBL ES250P subwoofer to full functionality.
  • The L30D amplifier module operates now with enhanced thermal management and integrated protection features.
  • Achieves optimized power consumption, cool component operation, and reliable performance.
  • Retains original subwoofer behaviors: automatic shutdown, output relay control, and comprehensive fault protection.
This comprehensive guide aims to assist others facing similar challenges with the JBL ES250P subwoofer, offering a detailed roadmap for effective amplifier module replacement and system integration.
