I want to replace every resistors in a tube amp for metal film ones, it's just that I have some problems :
-Can I put some 1% resistors to replace 5% and 10% ones?
-I don't want to pay 40$ to change every resistors, because there are 40 different values, and I need to buy 10 resistors each time even if I need only one.
Maybe I'll do the caps first instead. Which ones should I use to replace ceramics?
Some will tell you that using a different type of resistor will alter the sound of an amplifier...let your ears tell you if it was worth it.
higher precision will almost never hurt anything but your bank account when it comes to selecting components for audio.
Replacing caps that are leaky or dead (esp. electrolytics) will make the biggest improvement unless the rest is just garbage as well.
DragonMaster said:Which ones should I use to replace ceramics?
Fiml/foil poly caps are really good. Metallized polyester is lower in quality, but lots cheaper than film/foil and definately better than a ceramic.
I decided to replace the caps finally, especially wax paper ones.
When opening the amp I found two wires short(The wires melt together) that were just before a wax paper cap that already leaked in the preamp circuit.
This cap is in the signal path right before the tape out / power amp in and the first preamp tube.
Also, when I'm selecting tape head, I hear a continuous squeeee, which is so loud I hear it pretty good at minimum volume.
When is was on the kitchen table to see why it had problems, this amp 's tranny compared to the other made a loud hum and vibrated a lot more.
When the volume is at minimum, I hear tons of noise and when on maximum, as much as the other, even if the audio is the lowest at minimum and highest at max.
I think I should replace all the preamp caps because I tested all the tubes and they're all OK.
I'll re-post this in Tubes.
Scheme is at http://users.rcn.com/fiddler.interport/HF12.HTM, click on schematic next to the model name.
DragonMaster said:I want to replace every resistors in a tube amp for metal film ones
Hi there......make sure voltage ratings of this modern stuff is adequate....go for upper wattage ratings, as so much now is quoted at 70°C running which I don't like......Tube amps can tolerate a pretty large out of range working tolerance and function perfectly.......Remember all those amps built in the 50's with plus-minus 25% tolerance with rod resistors perhaps 50% out........and didn't the amps still sound good ?
Alot has been said about resistors/caps changing sound quality.....a noisy res will be noticeable if put in the anode load of a 1st stage but my experience is the components in the NFB loop are the culprits that can change the sound quality-. This area is hotly debated but I find tube amps which use between 15-18dB NFB are best sounding, regardless of the type of component beit polyester/polycarbonate/or S/M.
The earlier Mullard 20 Watt amp (p-p EL34) used 30dB NFB and that sounded tight & unrelaxed and no change of component type made a hoot of difference to the sound quality. I might get bollocked for this....so be it! I never had much respect for magazine articles on this..
The older carbon composition resistors make excellent grid stoppers simply because they are non-inductive, ideal for RF suppression. The earlier waxed silvered mica hold their values pretty well.
However recheck the older values and keep them for grid stoppers around the o/p tubes & UL taps..........This is an area where high mutual conductance tubes (gm or mA/V) can run into parasitic RF oscillation.
Compare the gm of a KT88 with a 6L6 and the 6L6 is as tame as a parrot. Considering the above comment; on the whole I wouldn't replace all the older carbon resistors in sensitive places in an amp unless there is a specific reason for doing so, i.e if they have cooked and values changed in service.
rich
Can poor connection of the case to mains cap be the problem?
Parts being replaced for now(Mouser):
1429-6104 to replace the .1µF wax paper cap that leaked and was next to a short.
1429-6224 to replace a .25µF wax paper that did not leaked but was next to the short.
1430-6333 to replace mains-case wax paper cap.
TVA1711 to replace the old orange electrolytic cap going to the output tubes to speakers tranny.
Now, I have to find replacement for all the small ceramics in the preamp circuit.
BTW, in the scheme, I know mfd represents µF, but what's mmf, pF?
Small Quantities
You don't have to buy 10 of each, you can buy resistors in small quantities, even singles, from Welborne Labs, Parts Connexion, Angela Instruments, Mouser and probably others too.
Resistors @ Mouser are min. 10 so I don't change them finally. But some caps can be bought 1 at the time. I'll only buy from Mouser and DigiKey since I'll buy tons of other things from them at the same time.
picoF and mm = nano?
I found after I posted this that mmf is pF, there isn't any pF s in the scheme.
mmF is micro micro farad. that's what they call it back then since they didn't have pico farad. but it's the same thing.
uF is 10^-6 F, so uuF or mmF is 10^-12 F, same as pF.
Now in 2006...
Does it mean I can use metal film everywhere except for grid-stoppers?
By the way, could I get an example of grid-stopper resistor on the HF-12 scheme? I don't even know what's a grid. (Apart that it's making part of a tube)
Scheme here : http://www.users.interport.net/~fiddler/HF12S.ZIP
DragonMaster said:Now in 2006...
Yes. Some exceptions and tips .. Overvoltage must be avoided on film resistors so for example on a P_P output transfomer as a R/C snubber these components are subjected to high voltages. Most film resistors are dissip rated at 70°C; a power amp under chassis after a hours'running with average ventilation can easily creep to car bonnet temps. I find film resistors will slightly decrease in value with temp rise. Carbon totally opposite.
Thick film types when over-heated will see a permanent change in resistance.
Generally I choose resistor dissip at 2 to 3 x circuit power rating depending on area.
Electrolytic Caps halve useful life at double temp rise. Some worse.....Use 105°C types.. It makes sense to put'em away from heat sources.
I always use a carbon resistor for the phase/HF correction R/C network in the 1st stage of a power amp. Power isn't an issue here, but these components shouldn't be inductive. It all depends on the amp design.
richj
Still haven't ordered but I think I'm going to go with Xicon 5W metal oxide for <200k and BC 3W Metal Film for 200k and up.
Metal oxides are typically used for power supplies. I don't tend to like their sound and avoid them unless I don't have anything else on hand.
Metal film resistors are likely to reduce the warmth from your amp (this isn't bad, just different). Avoid generic brands, they are a little hit and miss. Also, don't discount a mix of types in specific circuit locations.
Good luck with this, it should be a worthwhile experience.
Yes. If you trace a current path through an amp, it runs through the power supply.
Some more than others though. I would generally spend more on any cap that is directly supplying a stage. These caps are in fact in the signal path. After all, the output is taken from a circuit that flows through such a cap and is therefore intimately affected by it.
A stage is partially isolated from earlier parts of the ps, but the keyword here is partially.
Hmmmm
My experience is about opposite to yours with regard to carbon comps. The more I remove, the better things sound. I tend to use metal films for signal unless there is high voltage drops involved, then it's metal oxides.
Over many, many years and a ton of amps (or more) the metal oxides have been quieter and more stable. Not as much noise in phono preamps.
To each his own. I must say it's possible to get poor quality examples of each.
As for the supplies, the metal oxides will not sound any different than carbon comp. Your are bypassing the output aren't you? The signal does not run through the entire regulator circuit (unless it's a bad design), just the bypass at the output.
-Chris
-Chris
- Design & Build
- Parts
- Replacing all resistors in tube amp
