Replacing NJM2068 and NJM4580 by AD8620 or LM4562
You can replace NJM2068 by LM4562. NJM4580 requires more care, usually a high-current not-too-fast FET opamp is suitable. To utilize AD8620 requires some knowledge on the circuit. If it is well implemented, non prone to oscillation, with high input impedance and within supply specs, it should work well.
I think this has all been discussed before, but comparing datasheets for LM4562, LME49720, and LME49860, they sure look strikingly similar. Main exception would be LME49860 is specified for higher voltage rails.
IME they are very good audio opamps, but a possible weak point may be their sensitivity to radiated RF. In particular, IIRC, DECT wireless phone base stations in the near vicinity (say, maybe, 10ft. or so) of an unshielded LME49720 have been observed to produce periodic FFT spurs (@ 100Hz intervals, IIRC??).
In places less hospitable to LME49720, OPA1612 has proven to be a very useful opamp for dac I/V and or differential summing.
Samuel tested the RC4580 which is marketed as a "drop in replacement" for
the NJM4580 but it´s not the same chip.
The (original) NJM4580 is actually rather good and even used in ultra expensive
Accuphase products.
Hi, with a great pleasure I can reaffirm that your opinion is absolutely correct, Japanes ei Nisshinbo NJM20xx and 4580 are (although relatively cheaper) by class better products than its replacement.
Ti and others do have interest to make them at the same level as its primary production line of OPA class IC-s. Only really better substitution for NJM4580 for example as Pre-Amp can be no less then OPA2228 or even better OPA1612, but for that -3dB less noise (and distortion) over whole audio spectrum you will have to play premium extra. Avoid LM4562/LME49720 and OPA2134/2604 if you do not want to re-engineering circuitry to make it stable. Question is OPA1612 or even better if you can NJM8830. For me NJM8830 is ... better, it can really only compete with LT1028. Al of that is if you use them in pre-amp role. As exit or exit buffer Amp with low Gain NJM4580/2068 are SPOT-ON and do not touch them, although NJM8830 are even better and LM4562/LME49720 are also quite precise.
Best regards,
