Resistor with very low Temperature Coefficient.
The temperature coefficient is one piece of the puzzle, but it should be combined with an awareness of how the temperature of the resistor will be altered by the power that it will dissipate in a given application.
For resistors that will experience large voltage swings (NFB resistor for example), the voltage coefficient should also be considered.
Indeed. Instead of a feedback resistor of 20k feeding 1k to ground, use 21 identical 1k resistors and assuming iso-temperature, the temperature and voltage coefficient effects nicely cancel.
Jan
Made from resistor arrays ?
Are they arrays such that they have near same TC and near same temperatures ( as done in ICs ) ?
Or, all resistor arrays, just resistors put together.
Arrays I need: up to 9 same value resistors.
To make
R, 5R
R, 5R
R, 8R
R, 7R
