Rockford Fosgate P300-12
I bought 10 of these unit .. Subwoofer box with amp ..
Problem is all 10 of them have the ame issue amp will power up but i get no output..
I tested the subs and everyone works so the problem is with the amp part of the box..
Amp powers up but no output anyone have any ideas ?
I did some testing and the problem is on the power supply board somewhere ..
I have 1of these amps working so i will compare readings between boards to see if i can find the problem ..
1 of the amps was working when i bought it the guy told me none of them worked but when testing i found 1 working ..
Ill do some testing and let you know what i find
