Rockford Fosgate punch p1000-1BD
hey everyone,
i have this amp: Rockford p1000-1bd. I have a problem with this amplifier. It drains 3A in idle and it becomes hot without output in a few minutes. Is it normal?
I have already changed all the output feets but it is the same things.
Thank's all.
So, the problem is: the amplifier becomes hot After few minutes without load... So i open It and i changed all output MOSFET but they continue to heat up without a load. I check and It drain 3.2 amp without load...
I check with my oscilloscope on the gate and i posted the image before... I dont know what Is the problem
Do you understand now? :)
How hot is hot?
What is the part number on the class D driver board?
How did you get them when a mains powered scope? You can't ground to the transistor.
The waveforms are not that unusual. Below are the drive signals from an older but similar amp.
