Rubycon PMLCAP
They are interesting caps for large values, especially if the part must be reflow soldered and must be small and thin. The drawbacks as I see them are their very high cost and their low rated voltage. They also have very high dissipation factor (1-2%), but given their small size and high K, this is not surprising.
At this point, if you can tolerate the large size of an Al electrolytic, they will work a lot better and cost 10-50x less. However, they will have a finite life, whereas Acrylic film caps will not wear out. I was looking for a small cap around 10µF to use with an RMS detector, and I decided to use a conventional Al electrolytic instead of these caps, mostly because of their cost. YMMV.
