SB Acoustics Elok MTM
There are two serious issues with the SB ELOK in my opinion.
The volume of 15 liters simply is too small for two woofers. The result is a peak at 100 Hz and not much bass below.
The crossover at 4 kHz clearly is too high for an MTM speaker. The result is a terrible vertical dispersion pattern. Furthermore, the woofer break-ups starting at 5 kHz are hardly attenuated.
I think the SB woofers deserve a better design. In a larger cabinet, combined with a different tweeter and crossed at 2 kHz, they would perform much better.
