I have a 12v 4500mA nimH battery that I need a charger for.
I am not sure if it's easy or not to design a charger that might allow me charging them for now.
There two things I am not sure of: charger voltage and if I should use a series resistor, to allow 10% or 20% current only.
Any suggestions?
Any suggestions?
Take a look at this. or search Digi-Key for others.
http://ww1.microchip.com/downloads/en/DeviceDoc/51648a.pdf
I was thinking of something much simpler. Something like the Microchip project does need
a specifiic pcb board, which I don't know where to get, and several parts.
Not too easy, and probably not too cheap.
Something like this is probably closer to my idea:
http://talkingelectronics.com/projects/ChargingNiMH/ChargingNiMH.html
That will work but you have to monitor the charge status or you'll ruin the cells. I used to do that with Ni-Cads running 500 mA AA cells from dead to full in 20 minutes. The time I forgot to turn them off wasn't pretty.
G²
Take a look at the LM317 datasheet, it shows a current limited voltage regulator suitable for constant current/constant voltage charging with a Max. 1.5A output.
As counter culture says: "a current limited voltage regulator"
Or a voltage limited current source is what is needed for these types of batteries.
The simple resistor limited battery chargers were OK for lead-acid types.
My dad used to say: "A job worth doing is worth doing right."
Your choice.
Take care.
Your choice.
Take care.
Ni-mH need more than just CCS limited and Vreg charger.
This works for lead acid and Nicad.
The new battery technologies need much more sophisticated charging.
Just read the extract from the post2 link
2.2 FEATURES
The MCP1630 Low-Cost NiMH Battery Charger has the following features:
• Programmed parameters - modified in firmware
• Factory Settings:
- Preconditioning Charge Current =170 mA
- Preconditioning Threshold = 3V
- Constant Current Fast Charge = 1.35A
- Charge Termination based on delta - VBATT / delta time
- Charge Termination based on delta + TBATT / delta time, with external
thermistor installed
• Top Off Charge Current = 130 mA for 1 Hour
• Overvoltage protection (battery removed)
• Overcharge protection to prevent damaging the battery
• Overcurrent protection in the event of a shorted battery
• Battery reversal protection
• Input short circuit protection
• Overtemperature protection to prevent the battery from reaching too high a temperature
during charge
• Soft-start capability by holding the reference voltage low during power-up
• The MCP1630 Low-Cost NiMH Battery Charger has the flexibility to optimize the
charging algorithm for new battery technology, different battery chemistries or
different battery pack configurations
• Proprietary features can be added by modifying the firmware contained in the
PIC12F683
• The factory-programmed source code is available
• Ability to adapt to environmental effects, such as ambient temperature
To charge NiMH safely you need manual intervention or overvoltage foldback or temperature rise foldback. They need more care than NiCd cells.
- Power Supplies
- Schematic for 12v NimH battery charger
