Sharing speakers with multiple Amplifiers
Hi Everyone,
So I have a 2 way switch (https://www.amazon.com/gp/product/B093GSS8P7/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1) and currently I can switch between 2 amplifiers to my speakers. But I built a tube amp and now want to be able to switch at least 3 amps haha
I have not found anything commercially that can do this 😛
Has anyone come across something that can switch between 3 or more amps or have a link to building something ?
Thanks!
Herbert
Such switches are often safe on transistor amps, but if you un-load some tube amps while they are playing loud, they burn-up their output transformer.
You can't casually switch tube amps without great care. Use banana plugs or SpeakOn, recognized speaker connectors.
If each amplifier has 2 channels and each channel has 2 connections + and - and you want to switch 3 amplifiers you need a 4 pole 3 position switch. If 4 amplifiers then a 4 pole 4 position switch. You will need many binding posts. 4 for each amplifier and 4 for the speakers.
Thanks Cal, I am being picky but prefer binding posts like the one I posted and not the wire connectors (not sure what to call them) it seems a good set of banana plugs and space to move the wires is the easiest approach 😛
I once built a big crazy looking box with banana posts all over it, and a heavy duty rotary switch. It worked well for either four different amplifiers to a pair of speakers, or four different speaker pairs to the same amplifier. We used it for audio shows like RMAF.
Alas I can not remember the name of the switch, I just sent a spare one to a friend here on the forum. Bought at Digikey, I think.
one that you can run 6 amps on.
This claims "Impedance Protection Prevents Amplifier from Damaging Low Impedance Loads". Which is usually a lot of few-Ohm resistors. Which may not be what we want. (And may not work right "in reverse".)
https://www.pyleaudio.com/sku/PSS6/...t-Power,-Accepts-Speaker-Wires-Up-to-14-GaugeSure, I suppose a DIY geek could hack-out the excess bits. But combine with marginally cheezy connectors and surely low-bid switches, the "inexpensive" is relative.
A DIY geek would have spent 200 bucks building his own by now. The 40 dollar one shown that has a drawback or two works for me at my stage. I am wondering about the resistive network also. Because these are reversible and non powered I’m assuming it’s a simple bypass?
It‘s called the Pyle Pro PSS4. No link, I am on the tablet.
Buy one more and connect them in series.
Screenshot 2022-03-09 at 22-31-10 Scheme-it Free Online Schematic and Diagramming Tool DigiKey...png
This one can select up to 7 amplifier with IR remote controller.
https://www.amazon.com/dp/B004Y8MH3...jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
I've used a "Niles" speaker switch - backward - as an amplifier selector, allowing me to use a few different cable/connector sets coming onto the workbench.
Gives me output trouble sometimes with some amps and I cant figure out why. I know they have 2 big 20W resistors inside; 3 Ohms I think. Unsure how those operate with the switching. Googling "niles speaker selector schematic" gives you everything but; must be a closely guarded trade secret...
When there's such trouble, I'm usually plenty exasperated with everything else that's not going right - and just pull the "output" speaker leads off the Niles connector panel and connect directly to the amp under test. One problem down, N to go.
Reactions: PRR
