simple basic enclosure calculator for woofers ?
i tried the dpc program , but i don't have the knowledge to use it.
these are the woofer parameters
it is a car woofer
Usable Frequency Range: 20Hz – 1.2kHz • Recommended power amplifier range:18W – 400W • Continuous power handling: 300W • Voice coil diameter: 2.0” • Sensitivity (2.83 volt/1meter): 93dB • Impedance: 5 ohms • Thiele/Small Parameters • Free-air resonance (Fs): 28Hz • Total Damping (Qt): 0.43 • Equivalent volume of compliance (Vas): 10.42 cu.ft. • One-way linear excursion (Xmax): 0.3” • One-way excursion limit(Xsvs): 0.91” • Cone area (Sd): 140 sq. in. • Dimensions • Overall frame diameter: 15.1” (384mm) • Cut-out diameter: 13.6” (345mm) • Mounting Depth • Top mount: 6.6” (168mm) • Bottom mount: 7.2” (183mm
i wanted to know the port size and ported and sealed box size for it.
Well box calculators like WinISD and Unibox can offer several recommended alignments depending on what kind of sound you want to have and where your subwoofer will be located, in a car or in a house. I'll try to help you soon, but now I must study for my exam.
i would prefer the most musically accurate box results vs. what type of sound might be prefered by the listner.
thank you.
i was hoping there was a web site where you could just plug the parameters in and hit the calculate button.
:whazzat:
What volume do you have available ?
A 25 cu. ft box is correct. This speaker can go real low, but it needs a lot of volume to do so. It can be made smaller tho, somewhere around 100 ltrs. If you use 2 in isobaric configuration you can half that volume. 65 ltr closed, fully stuffed (isobaric) would be nice enough for use in a car.
Mvg Johan
6 cubic foot sealed give a Qtc of 0.707 which is ok.
With ported you could go a bit lower.
It's a good woofer for bass over 30 Hz ported and over 40 Hz sealed, unless you use a horn.
What's your budget? I think there is maybe something better for the money.
