Simple dual relay soft start
Hi guys,
I would like to ask your opinion about this dual relay soft start. I believe both schematic are based on Elektor.
I am doing a modified lay-out with ideas based on both schematic, but I have added parallel diodes on the relay coils. Will this be ok?
Thanks!
Reactions: Alexium
I've had this circuit (the one in the second picture) for many years in an amplifier with a 330 VA toroidal transformer. The R3 resistor burned at some point. This resistor limits inrush current at switch-on, whereafter C1 limits current (C1 should preferably be X2 rated or similar). I replaced it with a 2W resistor to be on the safe side. Otherwise the circuit has worked fine. I used a 24V relay (coil 1200 ohm).
That's indeed Elektor's schematic style. I'd add flyback diodes across the relay coils as well. I'm a bit puzzled why the Elektor folks didn't. You can also use a diode with a zener in series if you want the relay to de-energize a bit faster. I'm generally not a fan of powering the relays directly from the mains, but I suppose it can be made to work. There are voltage regulators that can handle mains input now. I'd consider using one of those.
I'm not a fan of resistor-based soft starts, though. The peak power dissipated in the resistor during the inrush event is substantial, so if you do go that route you need to find a resistor that can handle this peak power (which can be in the kW range). I much prefer an NTC or inrush limiter designed for the purpose. I've written quite a bit about that. You can read my thoughts here: The Ultimate Guide to Soft Start Design (Neurochrome).
Tom
Reactions: Bonsai and Alexium
I have used something quite similar as inrush protection for a 4000 VDC power supply @ 1 Amps. When switched on, the power supply was NOT loaded, so the circuit only took the inrush current of the transformer and capacitors. The resistors I used were suited for high power…
Regards, Gerrit
Reactions: de Ocampo
Tom
You don't need any diode across relay coil because there isn't a transistor switch before the coil.Sutch a diode is for transistor protection against relay reverse current.
