Does anyone have a pic of this area or a schematic ?
Or knows if the transistors are in the correct locations ?
Someone has worked in this before and amp is in protection so wanted to make sure these transistors are in correct locations
Replaced the drivers for the outputs .
I removed the outputs .
Amp is still stuck In protection mode .
Originally the amp came in with 2 shorted outputs I removed all outputs replaced the drivers 2x 2t but the amp remains in protection .
Any ideas ?
Any ideas ?
My mistake I misspoke in the last post .
I removed the outputs and replaced the drivers .
Amp powers up and produces +- 12 volts on opamps
Also produces +- 85 volts of rail .
The protection led is lit and never switches over to blue power led .
Any ideas what might cause this ?
Were you driving a signal into the amp?
Scope set to 2ms?
Do you see a drive on any of the output terminals of U3 or U4?
Scope set to 2ms?
What's the DC voltage on pin 3 and 4 of the 494?
What is the DC voltage on all 3 terminals of Q4 (near the 494)?
Lifted Q4
Blue light now protection led off
So far I see nothing wrong amp idles fine produces all correct voltages nothing heating up
- General Interest
- Car Audio
- Skar Audio RP-2000.1
