Hey guys,
I just got my hands on a blown AUDIOPIPE 2000.1D amp, from what i can figure out, it was probably screwed to a speaker box because the FET heatsink clamp came loose and hit the drain on one of the fets and blew both sides of the power rail fets, I can see that the resistors are smd code 100 which would be 10 Ohm.... my question is what wattage should I get and what size would they be.... also does anyone know the transistor numbers for this board?? as I can not read any numbers on them, they burnt off....
Measure the smt resistor and get the same size, which is also the same wattage.
See this chart: Resistor Sizes and Packages >> Resistor Guide
thank you
