Solder sucker
My solder sucker came a cropper:
attachment.php
It wasn't a particularly cheap one, nor had it gotten years and years of use. Anyone else had this happen?
Anyone recommend a brand that will give better longevity?
I am still using my old silver soldapult which is now mfg by a new co ? Available at mouser. I bought a new tip it fits my old unit
Aven is the mfg 17535 model does not look like they sell the anti-static version
Whatever you do, DON'T buy the Jonard Industries DP-140 from Mouser or anywhere else. I had this one for a few months and the cheap plastic trigger broke off, making the device almost useless. This item is a clone of the original Soldapullt model US 140, one of which I purchased over 40 years ago. That original solder sucker is well-worn but still working fine, unlike this new piece of crap that I bought as a spare.
Take care,
Doug
That's good, but I see that tool, not having enough volume as the larger one. I think it makes a difference in ability to remove. Maybe the smaller size is better to get into tight spots where the bigger tool might be a hinderance. best yet have both types 🙂
I still use the original silver soldapult. I contemplate getting an auto but the soldapult is so much easier to service.
happy de-soldering
I have two tools for removing solder. The first a, Precista Solder sucker is 30+ years old and still has the best performance of a manual sucker. it can generate enough high vacuum suction to clear a hole in a multilayer ground plane hole. They have not been made for many years. However for a recent project (replacing all the stitching transistors in the tuning of an audio analyzer) I got a Thermatronics desoldering kit NEW Thermaltronics DS-KIT-1 TMT-9000S Desolder Kit; Metcal Compatible MX-D001 | eBay and the speed and quality of its output is amazing. The 30 transistors were out in no time and the PCB looked new. Its an expensive commitment but the instrument is also expensive so a valid expense and I have used it many times since.
Take care,
Doug
The DP-100 is just as bad. Internal plastic parts break inside this one too.
Desolder Pump | Jonard
The Edsyn Soldapullt LOOKS very similar to the Jonard but is far better.
The Original Deluxe SOLDAPULLT: EDSYN Inc.
Jonards fail several times a year. Edsyns take several years to fail.
Used my new Engineer SS-02 in anger for the first time today. Suction definitely better than the previous one, and it's built like a tank which gives me the warm fuzzies.
But it *is* a little on the short side for the hand. Hopefully once I'm used to it I won't notice anymore....
