I have a kyocera player that the laser has died and I was wondering if I could install a KSS-240 or something like that. I am not sure the compatibility of all the sony lasers.
The KSS240 is totally different.
You might struggle to get a KSS152 now,
KSS152A Laser Optical Head Alternative
Google Image Result for http://www.dalbani.co.uk/images/products/thumbKSS152AThisisaKSS152ARlaserunit.jpg
As I know, there are no electrical different between the KSS-152 and the KSS-150A/KSS-210A. The only different there are the not present insert bearings (made of metal) for the KSS-152A-holes (look at the attached pictures and schematic)
Order additional a service manual with KSS-150A/KSS210A for compare and rule out electrical differences (e. g. DCD-810, DCD-820 from Denon)
The different between KSS-150A and KSS-210A also only mechanical; the first uses metal optical block and the second one with plastic (electrically full compatible).
Perhaps it is possible to change or matching the base unit chassis with help from a compact disc player used KSS-150A/210A
The KSS-240A is identical to the KSS-210A regarded the mechanic parameters, but electrical complete an other version (there are integrated preamplifier units by the OPIC resp PDIC). This means, you cannot use it for replace.
There are still a great amount of suppliers for the KSS-152A.
I am looking for a supplier, which can offer a KSS152A in a good quality.
Thank you for an advice.
About a PM I get an advice to this thread:
http://www.diyaudio.com/forums/digital-source/111364-looking-laser-unit-kenwood-dp-x9010.html
Hi,i've got a Kenwood cd player DP8020 which uses the sony KSS152a.This player is fantastic but my lens is malfunctioning,but i have changed already once and it worked but that was years ago and now i need another one.To come to the point is,i have tried the KSS152Ar and it just does not even recognise the lens.Please let me know where i can buy an original lens for this player.
Thanks for your help
Did you remove any shorting link on the new one ?
Audio Spare KSS152A (KSS 152A) - REPLACEMENT CD LASER UNIT (PICK UP) SONY
Yes,i have removed the the shorting circuit but the kss152ar series does not work.I would rather need a tip where i can buy an original kss152a for the kenwood player dp8020.On the replacement packet a part number is written J91034405.Its specific for this player.thx for your help Molly
- Digital Source
- Sony KSS-152 Replacement
