Hi folks!
I have a Sony TA-F6B which I recently was given, virtually for free. It's a lovely looking - and by all accounts sounding - amplifier so I'd like to get it working again.
The last owner said it made a loud popping sound one day, and hasn't worked since. After taking the amp apart, it's obvious the owner before him either did some tinkering, or gave it to a tech who cut a few corners...!
I have traced the problem to the PLPS (Pulse Locked Power Supply - basically a late 70s Sony SMPS I think). A heatsink/clamp to four power transistors was not replaced by previous owner/tech so in the end two of these met their maker! Worse he replaced two of the transistors with a different make, and all four are meant to be hFE/batch matched. There is also evidence of lifted solder pads and a jumper wire too in the following pics:
Here's what it should look like with the missing clamp:
http://picasaweb.google.com/895720/SONYTAF6BPLPS?feat=directlink#5325951198508682210
So basically, I need to know what an ideal modern substitute for the 'R' hFE grade, and 'O' hFE grade Sanken 2SC2023 power transistor would be please, as the original devices seem next to impossible to get hold of now.
Any help/advice would be gratefully received
Thanks,
- John
Thanks,
- John
The original specs for this part:
2SC2023 pdf, 2SC2023 description, 2SC2023 datasheets, 2SC2023 view ::: ALLDATASHEET :::
Those transistors with gold leads are bad news... look to replace them.
Fortunately there should be loads of suitable TO-220 transistors now that SMPS are all the rage. Fairchild are probably best to look at for this. The high Vceo and fast(ish, for those days) switching speed will be whats important here.
Thanks for the suggestion guys - much appreciated
I'm really no more than a 'solder by numbers' DIY guy so lack the knowledge about what parts are best to substitute.
The caps on the main board will be replaced with Panasonic and Rubycon 105C long life types (mostly FC/FM and ZLH low esr types).
Here's a scan of the PSU (or PLPS!):
- John
- John
Many thanks for that link Mooly but I already have the full service manual which I had to pay to download - the Hi-Fi Engine one is missing many pages.
Hi johnm
I'll try and have a look at the PSU in more detail later...
SMPS can be drastic in their failure modes, and it might help to see if the PSU would run off load and with a "bulb" limiter in the incoming mains supply. It's worth removing (if needed) semiconductors and checking accurately all the resistors as any that see a high voltage can be prone to change value and go high.
Looking from the circuit, Q601 and Q613 are just pass transistors - so as long as you've got a transistor with a high enough Vceo and Ic here, you'll be fine.
The other transistors are the primary side switching transistors in the SMPS. These are probably a bit more critical. I would say the BUT11A transistor that Mooly mentions would be suitable.
One advantage of old circuits like these - parts such as the 2SC2023 would have been top spec at the time, but now SMPS's are so common, so are equivalent (and evenb superior) specced transistors.
Yeah it's pretty old - the Sony TA-F6B amp came out 1977, and was manufactured until 1981 (Sony TA-F6B on TVK) so I'm hoping it will be fairly straight-forward to sub in new/better parts and get her working again.
Here's a cheeky link to another thread I started as 'ST70fan' over at Audio Karma yesterday (there's a few TA-F6B owners there):
http://mail.audiokarma.org/forums/showthread.php?p=4297238#post4297238
Once I have a consensus on here which parts are best to sub for the transistors I'll get to work on it - afraid I totally lack knowledge about transistor subs alas. Really grateful for all the help here
I've printed the PSU out... I'll see what I can come up with as regards transistors and a means of testing.
You need to 100% sure all the resistors are OK, particularly the 0.22 ohm (R622 is it... bit blurry). Check them all.
I think a small 60 watt or filament bulb would be OK as a light (ha ) load across the secondaries with the feed to the amp disconnected (looks like plug/socket... if not then by lifting L607 and 608).
The main reason they specify the same hFE on Q609-Q612 is because they form a self oscillating circuit. If the transistors were wildly different on gain, the circuit would oscillate unevenly - or may not at all. Gain should not be a problem on modern transistors
I think that explains (along with the missing clamp/heatsink) why this PSU blew as the parts seem to have been placed with no heed given to the service manual at all. Q609-Q612 are currently: 2SC2023-0p, 2SC2023-R, and two NEC C2335s which are from different batches. I guess it probably was oscillating, and over-heating too :s
First thing first - will desolder all those transistors over the weekend, and really give the board a really good clean up, and repair any damaged/missing solder pads. Will then be in a better position to install new parts.
EDIT: Q602 (the one to the right of the two red ones in the pictures) looks a bit dodgy too so will replace that also - it's originally a 2SC1775F for the UK model.
Wow speedy gonzales haha! Thanks Mooly - so you mean (once all fixed up again) I'd apply power to the PLPS and then see if the bulb lights up or not collected to the secondaries?
Is it straightforward to test the resistors when in circuit? I thought some of them might have different values as they're all interacting?
p.s. the photo back in post.8 is clearer than the scan in that manual.
- Sony TA-F6B PSU repair
