Sound Damping and absorption material
Hi Everyone.
Need your opinion if you had any experience with these products.
I am considering Elephant Shield Rubber paint for sound damping and sealing wood speaker cabinet(Using wood for body and ply boards for bracing) - Anyone had any experience with this product for sound damping?
Considering ROCKWOOL ROXUL Safe and Silent for sound absorption - Is it good for this purpose?
I am looking for good and low cost solution for wood damping and sound absorption which are available locally.
Other option i have available locally
1. Polyfill/Glasswool
2. Bitumen Sheet Self Adhesive - Black
Thankyou
Rockwool or denim insulation are both great for sound absorption.
As for the damping, I tried using Flex Seal, which is a rubberized paint that I'm assuming is similar to what you are asking about, and it didn't really do much. I think it would need to put on much thicker than is reasonably achievable to have much impact.
Thankyou for your feedback. Yes Elephant Shield is same - Rubber Paint.
Ordered Rockwool, for vibration damping also looked for thick rubber sheets like these "http://www.soundservice.co.uk/dedsheet-sound-damping-sheet.html" but its pricey. Search is on.
You can do CLD. It is very effective when you do it the right way.
Thankyou, I am reading about CLD.
Roxul is what everyone recommends over at studio building gearslutz.
it works.
for vibration, sylomer or sorbothane
Thankyou, these are best products out there for vibration damping but they are very expensive.
How good is natural rubber sheet(4mm thick) for vibration damping, anyone tried?
BASF’s patent on “Basotect” reticulated melamine foam expired. Hence they are made in China as magic eraser sponges. The porosity ratio can’t be beat. They weigh nothing and are fire retardant. The acoustic damping is superb. I have not found anything better. It beats felt, fiberglass, rock wool, and polyfill.
Damping Materials
Electron microscope image:
I have found that lining back side of box where driver cone has line of sight - removes boxiness completely.
Best of all, it’s cheap. 100x pads for $6 etc.
20/50/100PCS Cleaning Magic Sponge Eraser Melamine Cleaner Multi-functional Foam | eBay
I came upon melamine foam as an acoustic absorber for mobile audio. However, the thickness is limited and the melamine foam has to be hydrophobic. I recall reading that the typical 1/2" and 3/4" thickness limits absorption to frequencies above 4K or so. I can't recall where I saw that. However, I found this searching just now. Apparently NASA has performed the tests we'd find useful.
https://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20140008689.pdf
xrk971, thanks for bringing this to everyone's attention. Especially the really inexpensive pieces on eBay. I think I'll be using 2" thick melamine foam to line the backs of the 2-way enclosures I'm currently building.
One more point about the NASA data. I think for lining loudspeaker enclosures, the absorption would be equivalent to double the thickness used due to reflection from the enclosure wall. So 1" lining in a loudspeaker should result in absorption performance equivalent to 2" of foam in the study, which looked at absorption for the application of acoustic transmittance. Someone please correct me if I'm wrong here.
Thankyou everyone.
I have already purchased rockwool, now I am looking for something which is not foam and can absorb vibration.
Roof cement. It can be troweled on to the cabinet wall and leaving it uneven mitigates the sonic problems associated with parallel walls. You can add lightness by mixing in bean bag styrofoam balls (I’ve used the small ones, about 1/8” diameter).
Any absorptive material works most effectively in the open enclosure volume, not fixed to the walls where the particle velocity tends towards zero. Put another way, lining the enclosure walls is the most wasteful and least effective use of absorption.
The OP originally asked for damping AND absorption solutions. The roof cement is for damping the enclosure walls, certainly not for absorption. I should have been clearer in my post. Thanks for pointing that out.
Reactions: MrKlinky
The OP asked for damping AND absorption solutions. The roof cement is for damping the enclosure walls, certainly not for absorption. I should have been clearer in my post.
Hi Craig,
Sorry for any ambiguity in my post; I was making a general comment, not replying to your suggestion, which works well. I would add that if the damping material is solvent-based it should be given adequate time to release said solvents before the drivers are installed.
Cheers, Carl.
