sound level meter without recalibration
I read that there is a problem with sound level meters, sometimes you have to recalibrate. a possible alternative is to buy a sound level meter combined with a pistonphone but I think the price rises a lot.
so i ask you this, is there a cheap sound level meter that doesn't need to be recalibrated?.
Try the smart phone apps, at least they are cheap. Several years ago I compared an Android app to a calibrated meter and it was very close. You could also enter an "offset value" to get even closer. Now I have one called Sound Meter on the iPhone but haven't had a chance to compare it to a calibrated meter.
Reactions: arivel
It's not just SPL meters, calibration is needed with any measuring device if you want accurate enough measurements. There were inexpensive SPL "sound level" meters sold by Radio Shack a few decades ago, they worked ok. If you're doing something involving government or legal work, you surely need a measuring device that's traceable and calibrated to a known standard, and yes, that gets expensive.
I think the best alternative is to buy an old Apple iPhone 4 combined with an app
The trouble with that is the OS. It can be difficult to find the old apps that will work with iOS 9. They exist, but the App Store won’t let you see them.
I have two iPhone 4 that I would love to use for all sorts of things, but since they were cleaned off installing apps again is not easy.
Reactions: matulo_g
there is no ios 7 app outside of the apple store ?
If there are old apps outside the store, I don’t know how to find them. The iPhone 4 will go to iOS 9. Usually if you have already downloaded the app, AppStore will let you find older versions. But I’m not having much luck. I did have an SPL app and even a calibrated measurement mic on the iPhone 4, but now I’m having trouble re-installing it.
I’ll try again and update here. Maybe contacting the developer could help.
https://apps.apple.com/us/app/splnfft-noise-meter/id355396114
IOS 9
