Hi Everyone,
New member here. I have a Sony GTK-XB90 battery-powered Bluetooth speaker, weighs about 35lbs, pretty large.
It was exposed to some moisture, started to sound very static, and then I shut it off and let it dry out for a few days. It works now, BUT whenever it’s on, it has a low level hiss and it pops when the power button is pressed (on and off). I would like to remedy the issue and see it that I have 3 options:
I know how to solder, so if you think that I could potentially remedy the issue by replacing a capacitor or something (again don’t know amplifiers, so not sure what part could be the culprit), I would attempt that. I have seen a Sony manual on the web that had some sort of diagram of the main board if that is needed.
Any advice is greatly appreciated. I would be very satisfied if I could bring the speaker back to full functionality with a few cheap parts and my own hands. Thank you.
- I can replace the unit altogether with a used one for about $200 (don’t want to do this)
- I can replace the “main board” from Sony for about $150+shipping and if it turns out that it’s the power supply board, that’s another $50+shipping
- I can attempt to repair the board myself, but admittedly don’t know what I am doing
For reference
Here is a link to the power supply board:
https://www.needapart.co.nz/products/sony-stereo-power-board-complete-988521958
Main Board:
https://www.needapart.co.nz/products/sony-speaker-main-board-uc2-988522317
And factory Service Manual:
https://www.manualslib.com/manual/2087670/Sony-Gtk-Xb90.html?page=21#manual
Main Board:
I repaired plenty of these units out of warranty due to liquid spillage. Highly recommend replace the main board complete.
Thanks for the reply— might be going this route. Will updateI repaired plenty of these units out of warranty due to liquid spillage. Highly recommend replace the main board complete.
Try dumping the electronics in a vat of iso-propyl alcohol for a couple of hours with gentle agitation every 10 or 20 minutes. Then drain and sit them on a warm radiator for a couple of days?
Agree. Search if between the pins or terminal of the components, appeared a blue-ish or white-ish aspect like a foam. Remove it with care and a soft brush wet in isoprophyl alcohol. It was a recurrent problem in my last job repairing industrial electronics. Let it dry some hours.
Warning: this thing may have lithium batteries, and a shortcircuit, overload, over or under charge may cause it to ignite.
Got some 99% IPA. Took the speaker apart and examined the board. There were no signs of corrosion or water damage. A bit of a haze on the bottom side of the board which may have been some sort of residue but I think the culprit was what looked to be a short on the main chip under the heat sink. Looked like it burned up the thermal paste and left some black dusty stuff in the area. I dunked the board in the alcohol for a few minutes and cleaned it up with an old toothbrush.
I cleaned up the power board after because it had a hazy film on the bottom as well.
Both are drying now and I will reassemble with new thermal paste tomorrow night to test. Hopefully the chip is not permanently damaged and what I was experiencing with the hissing was a result of the junk on the board or the film on the bottom potentially shorting something out.
Upon further examination, leg 24 of the TAS5342A amp chip is blown/broken in the middle of the leg
- Class D
- Speaker Repair Help - Hissing / Popping / Amp Water damage Sony GTK-XB90
