Hello, I found this DMS-10 in an old Volvo I was parting out a couple years back. I came across it again while cleaning out - and I'm looking to find it a home.
The front LCD doesn't turn on, but there is life! I tested the outputs with an oscilloscope and found various ~24v waveforms.
The unit is a little banged up, some scratches and dings on the aluminum case.
I'm new here and not much of an audio enthusiast myself, but I have seen how much a DMC-10 combo can go for...
Considering the condition and niche market I'd be willing to accept as much as someone is willing to pay for it, and at the end of the day I just want to see it go to use one way or another.
I was considering keeping it as a power supply to build a DIY analog synth sometime in the future...
But I've seen a thread here where someone was missing their DMC10 power supply and ended up using two separate 24v power supplies and made it work... but I figured someone may want the original thing 😉
Various readings from o-scope:
(Had it plugged into power inverter - not true sine, not sure if this affects the waveform, or what would be normal, or whether I actually squared up the wave on the scope to get an accurate V/AC reading, or which pins I should have been checking between so I tried all combinations
But at least it shows that something is going on in there
