STK-077 output offset
Hello Everyone,
I was given an older HIFI stereo radio, an Unitra Mercury. https://www.radiomuseum.org/r/diora_merkury_dsh_303dsh30.html
The PA uses STK-077 Sanyo hybrid chips, those are 20W amps, running from +/-21V rail voltage.
The output DC offset is bit more than I would like to see, those are 100mV and 85mV respectively, with no load, after about 15 minutes of warming up.
I do not want to replace the chips, I am thinking about adding offset adjustment circuits, like the Pioneer SX-1250 has.
Any comment on this?
Thanks, Peter
I would not worry about 1/10th Volt DC. It is less than 1% of the maximum output voltage and 0.01% of maximum output power. The idea of "zero!!!" output DC came after these chips.
But yes, you can trim it out.
Thanks for the comments!
My apologies for the late reply, I was away for awhile!
The only reason I was asking about the output offset that there were some sticky threads some time ago advocating 10mV to 30mV max offset for low distortion.
I do not recall the technical argument for the lower distortion.
That thread also could have on another forum...
Thanks again, Peter
