Subwoofer Amplifiers
Interesting solution for this task for example is one from Crown XLS 2 line. Yes this is not build directly for home use but has nice features like DSP crossover, EQ, RCA and XLR connections and more than enough output power even to low impedances. Even in Hifi circles it has a good reps of these amps.
Use PA amplifiers with DSP controls
All depends on what design you are using, how low it goes and other details. Some PA amps have limits on their high pass filters, say 20Hz and some of them have switches with a fixed frequency.
Some people snatch up the Behringer iNukes and manipulate and stack filters to force them to high pass lower--always an option. Do the research on whatever PA amp you desire, the XLS Crowns are quiet but the "DSP" is just crossover filters, if you want full delay control, parametric EQ and so on--get a Mini DSP and have a great time.
Good luck!
Your best bet in terms of price would be do get the popular inuke series from behringer. They have dsp versions that are very capable but mine had a large pop when it would power off so I had to return it. I read up on it and it seems to be an issue with the dsp units. So, my real recommendation is to get an inuke without dsp and get a small miniDSP 2x4 box. It has all of the EQ you could imagine. At $105 or $80 for the board (exact same unit, just no fancy aluminum box around it) it's a no brainer. That's what I've been doing for my ids-25 clone and it is great. Parts express is the place to go.
