I am rebuilding an old TAC Scorpion mixing console power supply - full re-cap and new volt. regulators.
While working, I noticed these resistors and thought I would go ahead and measure their values.
The schematic I found lists R3, R4, and R5 as 1 Ohm, 2.5 Watt. That schematic is located here: TAC PSU Schematic. (a note about this - my PCB is labeled JP294B on the underside and other than these resistor values, I haven't found a difference between my board and that schematic)
Anyway, all three of the above resistors test out at .5 Ohm. If I have the correct schematic, that is wrong.
Additionally, I noticed a slight discoloration on the underside of the PCB:
Are these guys in need of replacement? These are wirewound type, correct?
Thanks!
Thanks!
