Tap aluminum heatsink
Hello,
I need to tap two M3 holes in aluminum heatsinks. I have 3 pass 3mm taps.
I don't succeed to have nice threads. They finish "too big hole" and the screw slips in them.
I had the advice to use only the last finishing one, as aluminum is a rather soft metal. This is a bit better, but still not very nice.
I have difficulties to start and stay vertical...
How do you do ?
Any tips to tap heatsinks ?
JMF
There are several ways to do this.
1. Tap from the rear. This results in the thread at the working surface being better formed.
2. Fit a suitable metal plate on the face of the heatsink so that the loose hole is taken up in the scrap material.
3. Use a drill press.
Thanks for the tips.
I like the scrap metal plate idea.
How do you use a drill press to do the job? I would be afraid:
- either to press too hard
- or to break the tap ?
I drill at 2.5mm for M3, which looks like the "official" value.
JMF
Taps require a very steady and accurate hand control which is difficult to achieve with taps in the range of a few millimeters in diameter. My advice is to use a drill stand and work very slowly by manually rotating the chuck with your hand. If your holes came out to be too big, use small bolts through the heatsink.
2.5mm is too large for M3
You need to use 2mm.
It took me a while to figure that one out. Once I changed to 2mm I stopped having issues with laxity.
3mm for m4
I second using a drill press
I know its not considered good practice but........
I have also had great success using a cordless drill driver for taping m3 and m4 holes. I find that the freedom from having to provide rotation allows me to focus my limited brain power on jamming the tap as hard into the hole as possible till it bites and then things are easy.
I started lubricating "half way" in my tests, with WD40, and it improved the things. I'm turning the tap back when I have to force a bit more, which is more than every 1 or 1 1/2 turn.
I had the feeling that that back movement could participate to the messing of the threads in that soft material.
JMF
JMF
When the tap starts to force in the very cheap/soft aluminium (for chinese cases that is, I have never had a Modushop chassis so can't comment on the quality of the heatsink extrusion) you are already messing up the thread...even more though if you are tapping a blind hole and bottoming out
Stupid question, but I suppose your are lubricating as needed and turn the tap back half a turn out every 1 or 1 1/2 turn ?
Exactly!
2.5mm is what i use.
Use a stand drill for drilling not a hand drill!
Taping by hand i use w40 for lubricating, turn the tap back half a turn out every 1 turn. If you feel difficult turn, lubricate it again, or turn the tap back completely, labricate and try again.
Tap drill size chart Metric Tap Chart
+1 for comments by KatieandDad and Coolnose. Always pre-drill to at least 3 mm deeper than the projected bolt length - space permitting. I've always done the tapping by hand for the up to 4 mm(very carefully with WD40) and you must use a blind-hole tap. This is different to a through hole tap. Some videos for reference.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiF27nEl-3pAhWNZMAKHXjsAzAQwqsBMAB6BAhfEAQ&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DKo3CaRw9Ktk&usg=AOvVaw3DUDUG69txrfgl64OXmnUg
https://www.google.com/url?sa=t&rct...=X5Ef-MBSIFI&usg=AOvVaw0E4xLSfut-4iQAg_J_GzYE
Good luck, Kevin
P.S. If possible use a can of compressed air to blow out the hole after you have removed the tap. I also normaly take the tap totally out after every two full turns to clean the hole of swarf.
I also use the drill press (only turning the chuck by hand) for a few threads to be sure of starting vertically.
I can also vouch for the low powered, torque limited, battery drill-driver.
Set torque limiter to a suitably low value. Go slowly. The surest way to break taps is wobbling with the usual tee-handle. Cordless drill avoids this.
Use some lube, back off to break the swarf and completely remove tap if required to clear flutes. Small taps soon clog.
