I am sharing the file I got from my friend, it's a TDA1541A DAC with multiple input interface including I2S.
Also, for convenience there is a InterActive BOM that helps a lot while soldering components.
The attached .Zip file contains
A) GERBER files in Zip, ready for fabrication.
B) BOM in HTML.
Please let me know if there is problems.
Regards,
J
B) BOM in HTML.
Regards,
J
@jensenhoffman Nice project, thank you for sharing
... Difference between mine and this will be in the absence of digital filter ... you can then try both and compare![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thank you, I remember SAA7220 can be replaced by some logic parts to do NOS job, right?@jensenhoffman Nice project, thank you for sharing
... Difference between mine and this will be in the absence of digital filter ... you can then try both and compare![]()
So, I thinks it is still possible to make this a NOS TDA5141A D/A without digital filter.
New DACs with TDA1541A
Anyway, SAA7220 is a tough chip as it pollutes its own power supply. It would make sense to have ferrite beads and a local regulator close to it. There is something to be gained with direct improvement and simple parts.
TDA1315 is an odd choice if one wants the best results. Or is the vintage 1996 jitter desired for in 2022?![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
- Digital Line Level
- TDA1541A DAC Project Discussion
