Testing Frequency Response with an Android Phone
Hi
I have an Android smartphone, with Android v8.0.
I would like to test my audio system, and generate a FR graph.
What app is recommended to use, for Android?
Also,
should I trust the built-in microphone?
Or buy something external?
My phone has OTG, so I can connect an external USB Microphone
(Mic+ADC+USB Controller, thus not basing the test on the phone's Mic or ADC)
Thank you
I typically use a measuring mic that I sent away to be calibrated and a phantom mic amp / Holmimpulse on my laptop.
If I look for a peak in the measurement and then level it in DSP (Najda) I can see it's levelled and hear the difference.
I tried the same thing on my phone (Google Pixel Android 9 - not that this would make any difference really) measuring, I see pretty much the same peaks and troughs.
I've not tried tuning the bass frequencies solely with my phone yet though 🙂
The first post here may be useful, it includes links to other similar threads Best free/cheap apps for diy audio 2018
Looks great, thank you very much!
Interesting, so switching to phone did not have much difference..
Nice to hear.
(obviously it will change from phone to phone, depending on the components' quality..)
Thank you very much Speedysteve7.
Advanced Spectrum Analyzer Pro is also the first recommended app on the forum thread scottjoplin linked to. So it seems to be favored by many. Will install it this evening.
The purpose is to test my system, which is a computer with a DAC and 2 HS7 monitors.
Do I need to play some .WAV file on my PC?
(or run some program on it, that will generate the sound to be picked up by the phone+app?)
I use a calibrated mic I got from Parts Express along with the "Audio Tools" suite on the iPhone. Should be apps that work just as well on Android.
Dayton Audio iMM-6 Calibrated Measurement Microphone for Tablets iPhone iPad and Android
AudioTools | Studio Six Digital
Thank you Pano.
I wanted to buy that microphone from PE long ago,
yet I wonder why Parts Express did not make a USB one, that includes a built-in ADC..
Their current microphone depends on each phone's ADC, meaning results may vary a bit according to the quality of the ADC one got in his phone.
Including the ADC in the Mic, like in a USB Mic, would solve that, yet they did not release a product like that..
Some phones (I have seen this on Sony) have some sort of fixed internal filtering of the mic, but this should be pretty obvious when you look at the curves.
I have Sony Xperia 🙂
I've not used these but could be a good start..
Audio Test Tones by Audiolab on Spotify
Here are lots of bass test tones
Frequency Bass Test Tones 5HZ-100HZ on Spotify
Try them on your system and see what the phone app says.
Thank you very much
A small update..
I wrote in the previous post
It seems they did release one:
Dayton Audio UMM-6 USB Measurement Microphone
Not exactly cheap tho, 75$
I tried the test tones from Spotify and the phone app.
Very accurate (surprisingly so in fact) above 100Hz or so and up to about 12KHz.
Not so good outside of that.
All down to the phone's mic I guess.
It was never designed with this in mind..
Might be a lot better with a plug in mic?
I won't be using my phone to set my system's tapped horns up 😉
