Hello
HYS3C300 Power supply comes from an active subwoofer (Canton sub 600) and supplies power amplifier in class "D" and the preamplifier. I do not know the history of this failure and I do not know how the injury occurred.
With the power supply goes -7V symmetric + STB and power for the sake of power amplifiers (+ V GND) estimate of it is about 50V
The power supply will not boot no voltage + -7V output. I measured the bridge rectifier is checked 325VA DC fast diodes for the coincidence of the STB are working, t8 transistor (mosfet) to the original approx.
I'm stuck in a place because I have a problem with the identification of the part indicated by IC3 is 6 feet smd is written on it 32D06 if anyone knows what kind of system I would be grateful for information about him, visually no damage. What else should I check? Maybe someone has a diagram of a power supply with a similar topology that would have helped me a lot (If you have an oscilloscope available)
Adding photos PSU
Ps. I apologize for an error that says the translator
obrazki.elektroda.pl/9572795800_1423172062.jpg
obrazki.elektroda.pl/8381377400_1423172072.jpg
obrazki.elektroda.pl/5952004600_1423172066.jpg
obrazki.elektroda.pl/4775159400_1423172070.jpg
Adding photos PSU
hys3c210-cs
i have the same problem.. mine burned mistakenly pluging in a 220v outlet which my divice only rated 110v.. luckyly only the green disk componet next to a rectifier is damaged.. label is completly burned and imposible to identify the component.. has anyone figured it out?
Can someone please identify the VR1 "Green Disk" component next to the rectifier? Mine burned and is completely unreadable. My board is marked either HYS3C160-CS or HYS3C210-CS
if 32D06a is WS3252, you can buy it here
6 feet power SMD chip 32D06a 32D07a 32D08a 32D09a 32D10a New straight shot
or on alibaba..
or on alibaba..
Thanks for photos. They helped me to identify resistor values.
Here is reverse engineered part of schematics diagram.
Also some photos of my blown components.
Instead of blown CS1N60 MOSFET I've successfully used STQ2HNK60ZR-AP
Reason for blown components was failure of diode on secondary side. Very standard 1A diode went short. I like good quality of sound after fix![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I know this is an old thread, I believe thats a varistor VR.hys3c210-cs
- Power Supplies
- The SMPS HYS3C300 - No STBY + -7V identification element
