These Valves good for anything?
Hey guy's, Just got given a whole load of Valves, 3 small boxes to be precise! Not sure what most of them are or if they are any good but any help would be apreciatyed.
Amongst the lot so far i have recognised as being possibly usefull:
1 x Mullard ECC82 (white label, british made)
1 x Mullard ECF80 (yellow label, made in great britain)
11 x 6L6GT ( colomor, Edicron and some with no makers marks i can see, all apear to be NEW)
2x GEC? KT66 (british made)
Need help with the following though:
loads of EF184, probably about 15 of them, various makes, mostly brand new in boxes.
2x JAN - EF50 metal can valves.
Load of other EF50's with metal cans
1x 6J5G ( unknown make)
1x JAN - CHS6K7G
2x 6AU6 (marked "electronic tube" and "6AU6 A USA")
well, thats the first box gone through.. 🙂
any of the tubes i didnt recognise any use in audio?
Many Thanks,
Owen
First of all.. sorry for any mistakes.. i am a little drunk :cannotbe:
arnoldc:
I have a heathkit s33 amp that uses ECF80's as the drivers.. it sound's pretty good even if it is my only hifi valve amp. it has ECF 80's driveing EL84's.. SEP.. nice sounding amp and very much louder into 4 Ohms than my 25Watt PC solid state YAmaha amp..
I did have in mind a 6L6PP amp for guitar practice use (only guiotar valve amps i have are PPP and EL34 = 100 Watt)
mabey i can get a subwoofer amp out of the KT66's (they look damn cool being proper bottle shape n all.)
Eli Duttman:
This sounds good.. basically all the tubes except the EF50's and the 6K7G have a use now.. and this is only the first box of three! i noticed some rather tasty looking valves int he other boxes but didnt want to mention them yet because it would mess up my memory of what i have already listed and what i havent..
The box i posted is by far the best, mostly NOS valves... the other two boxes all apear to be used BUT there is a piesce of paper that shows they have all been tested and the values the person got from testing all the valves so he must have kept them because they are of use.. dosnt seem like the sort of person that would keep rubbish if that makes sense.. 🙂
Owen
Quad II owners will give you their daughter in exchange for a pair of NOS GEC KT66.
EF184 is excellent for valve CCS.
6L6GT could be used in the output stage of all manner of amplifiers in the 20W range.
Now, if you could just give me your address and leave the door open when you go away for the weekend...
The KT66's are used unfortunatley (i think, they look used, but i have never had a KT66 in my hands before so mabey they arent)
i'll have a look through the other boxes later and see what else there is, i can see now though that there might be a few interesting projects in this lot.. 😀
OWen
The 6AU6 is a real sleeper of a valve. Triode connected has a gain of about 36 and makes an excellent driver for output valves that don't need a lot of driving such as EL84. Anode load 10K cathode resistor 330 ohms. HT 250v. Current draw about 8mA. All in the RCA manual. And they sound nice. Can also be used as the pentode in a CCS.
2nd box is split up into 12 compartments..
compartment 1:
Mullard VP4A
Compartment 2:
Mullard SP4
Mullard FC4
Compartment 3:
2 x 6K7G
Mullard DK32
Compartment 4:
6K7GT
6Q7GT
6V6GT/G
6V6GT
Compartment 5:
EF50
Mullard EL33
Mazda U22
Compartment 6:
Mullard PM24M
Tungsram DD4
Compartment 7:
APV4
U50
Compartment 8:
Brimar 8D3
ECH35?? hard to read:s
2 x EF50
Compartment 9:
2 x EF80
ECL80
Compartment 10:
6K8G
6K8GT
6 x EF91
VR91
Compartment 11:
CV1091
2 x 6J5G
6J7G
Compartment 12:
4 x VR91
4 x ARP35
EF50
cheers, owen
