Threshold amplifier help, please!
Good morning, all,
I'm hoping that Nelson Pass or another expert here might be able to give me any advice on any electronic components I might be able to test (and replace) myself as I have a hissing sound coming from the right channel of my T800. When I power down the amplifier, I also get a fairly long hiss with high-pitched sounds mixed in, only on the right channel.
It wasn't likely that this was going to be any of the top fuses but I did verify that those fuses are all OK.
Any help much appreciated!
Best,
Ross
In such an old amplifier, this could be instability or oscillation due to dried out electrolytic capacitors.
Unless you have previous electronic experience, such repairs should be done by an experienced technician.
The circuit board could be damaged, or other problems could be caused.
