do you know Xe gas thyratrons, average current 0,5-1A octal socket (or similar..)
best if, are still sold on ebay.
br-
br-
I can offer you thyratrons Hg, these are sold locally here.
High-voltage mercury thyratron ТР1-6/15 6.5 A 15 kV
Not sure about the shipment rules about such stuff though.
For that current (½ to 1 amp) type 6012 has octal socket. There are some on American eBay right now.do you know Xe gas thyratrons, average current 0,5-1A octal socket (or similar..) best if, are still sold on ebay.
Edit: If higher voltage is needed, please state rating.
I was going to mention the 2050 but the cathode current is too humble. Averaging .1 - .2 Amps verses .5A for the 6012. If course if a 4 pin socket is OK, then there are several other choices available.Why not a humble 2050, available all over the place, bog-std Xe thyratron (cheap, too).
I missed the decimal point on the 2050 data sheet. There are several Soviet offerings for Xe-filled devices on E-pay that meet the av current spec and are cheaper than the 6021, more choices if you don't mind a plate cap.
I always thought ~gas filled thyratrons~ were utilized for the ''light show'', mostly. Dunno - I'm neither old enough to seek out exotic AC-->DC rectification methods, nor young enough to want light shows (and precious little else).
An old goat.
I rather enjoy the near-indestructability of C4D02120A
gg
An old goat.
gg
Places you would think of using a thyristor, you can use a thyratron. They still have a place for switching HV.
For a low current device, the 2D21 would be a likely prospect. Maybe you could use a bunch of them to build a Trautonium....
Thyratron relaxation oscillators are apparently pretty stable thermally - you could augment them with pentode current sources (submini?). The thyratrons can also be strung together to make ring counters and dividers.
thanks a lot for suggestions, i hoped for something <4A heater and mesh anodes - or visible glow.
(basically replacement for 394A)
S1.3/30dV Xenon Gas Filled Thyratron Tube, WF (RFT), NOS S1,3/30dV Tube - 1pcs | eBay
Found this one, but 9A is just too much
it seems even Xe diodes have boxed structure -cannot look inside.. why ??
mercury no problem..
- Tubes / Valves
- thyratrons Xe
