Hello
I have a Tivoli Model DAB radio but since about a month ago, the national station changed from the DAB signal to the DAB+ signal which means I can't listen to these stations anymore.
Is there a way to replace the current receiver with one that can capture the DAB+ signal?
Thanks!
Thanks!
Unfortunately a DAB only radio can not be converted to receive (or decode) DAB+
The two systems are fundamentally different with DAB using the old MP2 standard and DAB+ using aacPlus HE v2
This means a replacement radio to receive new DAB+ transmissions. Probably not what you wanted to hear 🙁
In some cases a firmware upgrade will do it, but not all DAB radios have facilities for the user to upgrade the firmware.
In Australia the same thing happened, we started with experimental transmissions of DAB many jumped in too early and imported dab tuners from the UK, then in a year or so the authorities in Australia in their wisdom changed it to the inferior dab+, so now we have a few dab tuner on ebay for sale to unwary purchasers.
Cheers George
Cheers George
That's unfortunate to hear... I didn't think it was this complicated. Thought to put another receiver in it and done but seems like I need to buy a completely new radio... that's a bummer in this time of the year.
Thanks for the information!
