TL084/TLO74 replacements
The idea is to simply remove the IC and drop in another one. I don't have space on the board to squeezy anything else in there. Unfortunately the OPA4134 isn't available in 14-DIP any more. I experimented by using 2X OPA4132 and the results were fair. The sound was very transparent, but didn't have as much bottom end as the TL084 did.
So, yes this is a quad and I'm still hunting for a 14-DIP replacement. Thank you.
OPA4227 and OPA4228 come in DIP-14 per the TI datasheet. The "7" is optimised for unity gain while the "8" for gain>5. Both clain very low noise and distortion. They have limits on current seen at the input but I doubt that would be a problen when the source is a phono cartridge.
I'm sure there are other possabilities but these just now came to mind.
I've got a JBL 6230 power amp which uses two TL084 quads. Wondering the same thing: any recommendable drop-in replacements? My amp has them mounted in sockets (whoop whoop).
I know there have been changes in op amp technology since 2004. Anybody have a recommendation?
Looks like the AD713 could be a good choice. It's marketed as an upgrade for TL084: http://www.hep.uiuc.edu/cleo/trig3/boards/tile/vme021d_data_sheets/ad713.pdf
Yei, I just desoldered a dozen AD713, will have to try to upgrade some basic power amps too 🙂 Got some TL054 too, anyone have any opinion on them. They are more expensive than the most basic TL opamps at least...if that means anything 🙂
