TL494 Full Bridge 900 watt DC-DC converter
I am working on a full bridge boost converter capable of putting 900 watts into a load. This is based upon TL494 pwm generator from Texas instruments. TL494 is made to work in complementary output logic.
But there is a little problem with the mosfet deriving stage. I am using the standard circuit given in the datasheet of IRS2110 mosfet driver.
Mosfet used are IRF540N.
Converter lasts only for just a second😕. I have checked the output of TL494 on oscilloscope its is working fine at 50khz frequency. I have doubt on mosfet driving circuit. Please suggest me possible areas of fault.
Max power is 600 watts now. I have made half bridge boost converter.
It works fine without rectifying diodes. if diodes are connected then no load current goes high up to 2.5A at duty cycle above 80%. Mosfet are just warming a little.
Dead time provided by TL494 is at default value and is approximated as 7-8%.
What can be the problem? Suggest me the area of improvements in design of snubber circuit and gate driving circuit.
