Transformer fuse rating <25VA
Hi all.
I have been reading conflicting arguments when it comes to fuse sizing for transformers. Especially when it comes to smaller transformers say <25VA.
To complicate things further some manufactures include a thermal fuse in the windings.
Reading some of Rod Elliotts articles suggests that smaller transformers can’t be made safer with the use of external fuses. I still can’t understand why he says so. Maybe someone can explain?
I have opened up many wall wart type packs only to find no fuses and sometimes only thermal fuses. What if i find a replacement transformer that has no thermal fuse?
I do mainly repairs and want to give my clients the assurance when having to replace a transformer in their gear.
Thank you in advance all!!
One practical problem is that it is hard to find very low rated fuses.
I guess that 25VA limit comes from having minimum 0.1A fuses (in a 220-240V Country)
I also guess, and not too comfortable with that, manufacturers "think" the very thin primary winding wire will act as a fuse ..... what could go wrong? 🙄
If you want to protect the load, use a fuse on the secondary which makes the task easier.
The so called thermal "fuse" is not "a FUSE" in the normal meaning, it does not react to current but temperature.
Reactions: TonyTecson
