TRiode VP-300BD in stock $2,485.00
VP-300BD in st0ck
Price $ 2,485.00 (included side panel $100)
300B parallel single ended integrated amplifier
■ maximum output: -- 20W+20W (8 ohms) fixed bias
■ output tube: -- 300B class A single -ended
■ output:impedance 4 / 8 / 16 ohm
■ KOA highly precise resistor
■ Alps high quality volume
■ Frequency response 5Hz- 60 kHz (+1,-1dB)
■ Total distortion < 0.1%(1kHz)
■ SN level 95dB
■ Input sencitivity 0.5V
■ Tubes 300B * 2 , 6SN7 * 2 ,12AT7 * 1
■ Input terminals, ,unballance 4
■ Power sanction 250watts
■ demention:430Wx210Hx 320Dmm
■ weight:20kg
■ Tube cover, AC cable
I see the nanny state has come to wag it's little finger at us. Let's all go home because class d is all that is allowed. From Nelson Pass' FAQ:
Q: Isn't Class A bad for the environment?
A: Everything is bad for the environment, in case you haven't noticed. When I look at the cost of enjoying my 25 watt/ch class A amplifier as compared to watching a big screen television or running a porch light all night, I see that I get as much or more value for the same sort of consumption. If I drive down the hill to shop at Fry's, I consume about as much power as running one of my amplifiers for 2 hours a day for a year. So I go to Fry's less often, and I turn the amp off when I'm done.
In these days of energy saving lighting etc to try and "save the planet", an amplifier that is only 10% efficient is not a good design.
