tube opamps
Ralphie,
Take a look at this recent thread.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=36157&highlight=
A very nice active tone control circuit built around 12AX7s is discussed.
You could "copy" a discrete part FET opamp circuit. The I/P circuitry of opamps is a differential topology that (big surprise 😉 ) was 1st developed using vacuum triodes.
IMO, Max Robinson's Baxandall circuitry described in the thread is what you should build.
For a classical feedback Baxandall tone control you don’t need an op-amp, just an inverting gain stage. If you keep maximum bass boost/cut and treble boost/cut moderate to say + and – 10 dB (who needs more?) a gain of 20 to 30 will suffice. At the moment I am working on a new tube pre-amp with tone control. Simulations with a 6DJ8 as mu follower (gain = 30) seems promising so far. But I haven’t built anything yet, so I am hesitating putting up a premature circuit here.
Cheers 😉
