Tube Output Stage for CD Player
Here's hoping that someone can help.
Some years ago, maybe 20!!, I read an article about adding a tube output to a cd player.
2 circuits were given, one for the TDA1541A type dac and the other for the bitstream dac as used in the Philips CD63.
Does anyone know where I can find the article?
Andy
Long article! I'm a fan of using transformers on voltage out DACs as mentioned in the article. I've done this with a number of different DACs and with transformers from Sowther, Jensen, Cinemag, Onetics and Edcor. All with various degrees of success. I used to do transformer outs on the DCX2496 (also mentioned) with good results.
But if you want a current out DAC, then transformer is probably not the way to go.
Let us know what you build!
The grounded grid (or grounded base) topology is the only sensible choice for the TDA.
lcsaszar,
I am sorry to say, but that`s not a nice twist. There is no reason to use a high distortion push-pull amplifier. Otherwise I like your posts very much.
