Tubelab SSE Diode D1 and D2 source / part number?
I am working on my first build and the resistors and capacitors are all in. I was starting on the semiconductors and when I got to D1 and D2 I found I have a problem.
I thought I ordered the right part number from Mouser for the Diodes that go in D1 and D2 (1200 PIV FRED diode TO-220 pkg) but the spacing on the diode is about twice as wide as the board, so they will not work, does anybody have a good part number for them from Digikey or Mouser?
Also, I am planning on using a choke and a tube rectifier, so does that mean I can (or must) omit these?
Thanks,
Scott
