Upgrading the Aune X1 SE/Pro HeadAmp/DAC/Pre-amp
Dear members,
This will be my first post. I have been reading on this forum and some other forums about DIY audio and just recently I did my first audio mod on the Aune T1 Tube DAC. I replaced some capacitors with higher grade ones and it was a great succes in terms op sound quality (although I did fry the built in Headamp with soldering, but luckily I didnt use it anyway. I was hoping it improved a bit).
Currently I am using my Aune T1 DAC (with Elna Silmic II caps and Amperex 7308 tube) connected to my Aune X1 SE/Pro headphone amp/pre-amp to drive my Beyerdynamic DT1770 and QMS Q5 monitor speakers.
The Aune T1 is a really sweet sounding device but has no pre-amp and the headphone amp was not sufficient enough. So I bought the Aune X1 SE/Pro for its headphone- and pre-amp capabilities. The headphone amp is powerfull enough to drive the DT1770 nicely and the Pre-amp is feeding my active monitors fine. I love the Aune T1 DAC tube sound and with the new capacitors is sounding really clean, but I can't shake the feeling that the Aune X1 is adding some noise in the final output. Don't get me wrong, for this price the X1 is doing a more than fine job being so multi purpose and decent quality.
I like its design and functions and I think in base it's a fine product. I'm just looking to improve it like I did with the Aune T1 which really shines after the mod. I am trying to figure what all the components are on the board by using logic and a lot of google, since i have never been interested or schooled in these kind of things. My knowledge about electric circuitry doesn't go any further than the science lessons I had in High School, and that was a looong time ago. But I am willing to learn! And this forums seems like a good starting point. I'm quite good with mechanics, computer hard and soft-ware and all kinds of technical stuff so I think it is time to jump into the audio electronica and teach myself some basic stuff.
I am open to links and websites where I can have a good beginners read about where to start with DIY audio.
My second project will be the Aune X1. I cannot find a schematic for the device yet, but maybe other were more lucky. (I don't know how to read on yet anyway. Got to look up all the symbols again.)
Like I said before I use this device as a pre-amp and headphone amp, since I think the Aune T1 does a better job at the DAC part. I am mostly interested in improving the sound quality of the Headphone amp section and the pre-amp section.
This is the device PCB with the components.
By following the PCB lines I tried to figure out which section was doing what. But I'm not there yet.
After the modification I did on the Aune T1 I got quite fond of the Silmic II caps. I could of course replace most of the caps by Silmic II caps in the audio section, but I've read that the Nichicon FW themselves are not so bad either, so I wouldnt know if this would be an interesting upgrade. The big Nichicon FW in the power circuit is probably decent enough to not replace it by something else.
Also I see these black things with holes in them on the Headphone amp. By googling the serie numbers I didnt got any wiser. Except for the one next to the RCA jacks. This one is some kind of chip amplifier? Probably used for the pre-amp section?
Like I said before I'm a total noob at this. I am using my common sense to decipher this thing. I think the PCB is nice and clean and I think this could be a really interesting project to start with before I go up to some more interesting stuff to start understanding the basics.
Any help on this? Any guidance and explaination is welcome. I'm in 'sponge mode'.
Thnx
Beyerdyamic DT-1770 Pro wiring
Hello, I was hoping you might be able to confirm the wiring information I have for the DT-1770. With TRS plug, T=L+, R=R+, S=Ground, to 3-pin mini XLR jack Pin 1=Ground, Pin2= R+, and Pin 3=L+. I really appreciate your help. I've contacted Beyerdynamic and strangely enough they could not answer this question. I'm pretty sure this is correct but why guess? I'm assuming, I hope correctly, that you have a volt/ohm meter judging by your upgrade to Aune unit. Thanks in advance for your help. Best Regards, Ted Paisley
