Did anyone know a USB audio codec which has a SPDIF or I2S output? I know the PCM2902 but are there other chips? I'd prefer 24 bit and 96 kHz samplingrate if possible.
Hi matjans,
thank you. I think there should be chips with higher datarates and resolution available as there are USB soundcards with 96 kHz and 24 bit on the market.
Unfortunately 96 kHz and 24 bit chips does not exist AFAIK. All the soundcards 96/24 use custom solutions, and require drivers, with all the complications that this involves.
well of course there are, ti just doesn't have them as all-on-chip variants... Get a separates, build a board, write a driver and that's it ...
afaik, the standard usb audio drivers included with windows (nt, 2k, xp whatever) only support data rates up to 48kHz, 16 bits. (somebody please prove me wrong)
This is not really an answer to your question but M-audio produces a cheap USB Audio Interface (24bits 96kHz) called Transit I don't know what chip they are using. You can use this little interface as a start. Red Wine Audio do some mods on this unit to transform it into there USB select unit.
..actually, the PCM2902/6 works also at 96 kHz, also up to 100 kHz. But its bandwidth is limited to 24 kHz. Here are some loopback tests done on a soundcard that I designed, based on the PCM2902/6.
(PCM2902 and PCM2906 are basically the same chip)
The bandwidth is obtained from the FFT of the loopback impulse response.
Loopback at 48 kHz:
(click to enlarge)
Loopback at 96 kHz:
(click to enlarge)
The bandwitdth limit is visible and measurable
I checked the SPDIF output of the PCM2906 at 96 kHz, full of hopes.. but it is limited to 48 kHz:
(click to enlarge)
The SPDIF out from the PCM2906 has been analized using the digital input of another soundcard (by RME) that allows to analyze the incoming digital data
Loopback at 48 kHz:
(click to enlarge)
Loopback at 96 kHz:
(click to enlarge)
(click to enlarge)
Yes, I know using a generic USB device controller and writing some lines of code can support anything I'm looking for. Unfortunately it takes some month of work...
I just took a look to the Cypress CY7C6801x series. Seems to be possible when using an additional FPGA.
Interesting that it works at least. Maybe the driver itselves limits the datarate to 48kHz?
I'm more inclined to think that is a limit in the firmware on the chip..
But don't have a final word.
- Digital Source
- USB audio codec with SPDIF or I2S out
