Valve Amplification Company CLA1 mkii help
Greetings all you there!!!!
Iam newbie here and i want desperately help for my VAC CLA1 mkii line amplifier.Ihave problem with the power supply.The high voltage regulator TL783C burnt and the result is the two parallel resistors on the 470Ω(the big black resistor) burnt too. (i will provide you with photos),is on the B+rail.But due to the fact that they are crisped i can't read the value of the resistor(which is parallel to the 470Ω resistor),so i could replace it.I wrote to the company for help and the schematics but they didn't wrote me back.I would be really grateful if someone knows witch have the same line amp the value of the resistor!!!!
