Friends I am new in DIY and found a driver Visaton W130X that is different and not much data on implementation.
Idea is for 2 applications Powerful Bookshelf 2 way maybe 1 Full and 130x as woofer or 2 woofers
and a Compact Hideaway type subwoofer that can be used for music and movies
1-2 drivers room is 16ft -25ft
Experts please suggest
regards
anand
regards
anand
?? this is a current production model from Visaton and the data sheet is pretty complete, are you looking for a completely designed kit perhaps?
The only thing I can say about it, is that for that price there are much better (sub)woofers available.
Also 3mm xmax = (12-6)/2 is nothing to be really proud of.
W 130 X - 2 x 4 Ohm | Visaton
Visaton has DIY kit called Pacto , is that goo denogh or better optiosn to get they say its a Good bass in compact size
Suggest a Fullrange system as much as possible so that I dont need to get seperate SUBS
Visaton BG20 perhaps? just to be clear the concept of fullrange assumes a single driver or are you wanting wide frequency range as in multiway?
I can suggest a billion ideas, but first we need to know the context.
Like budget, size, use case etc etc
funny i've never seen this page before, i have a couple of the W130 2x4 woofers and have had a hard time modelling them with a tweeter. But now all of a sudden i've found the reference to the PACTO. going to look into this simple design for a different build build hopefully similar volume
Hi Did you try the Pacto or something with W130Xfunny i've never seen this page before, i have a couple of the W130 2x4 woofers and have had a hard time modelling them with a tweeter. But now all of a sudden i've found the reference to the PACTO. going to look into this simple design for a different build build hopefully similar volume
- Subwoofers
- Visaton W130X
