Watts or Db/watt ?
Hi all
Sorry for my ignorance, but a friend of mine gave me his old speakers wich are Magnat Sonobull 120, and i saw in technical data that they have a sensibility of 1,2 watts, now, can i convert this in Db/watt ?
I conected them to my 2 W tube amp and i am very pleased with the sound !
Hi all
I connected them to my 2 W tube amp and i am very pleased with the sound !
Usually the sensitivity is measured as dB of SPL output at 2.83VAC input at 1 meter, on the main speaker axis in an anechoic chamber (or outdoors).
Often the frequency is 400Hz. Probably the implied output for 1.2W is 90dB, so it would be 90dB/1.2W.
sensitivity, and 1.2 watts
el₁₅₆;4117849 said:
Hi all
Almost always a "sensitivity" is relative to the amount of power to produce a sound level of 100 dB, at 1 meter from the center of the front-face of the speaker enclosure. I vaguely remember that the speaker cabinet also has to be ½ meter lifted above the ground (the base), too.
100 dB at 1 m, with 1.2 W input is quite good.
If you like the sound from your 2 W amplifier, even better.
It probably gets pleasingly loud during the more potent music transitions.
And of course, your 2 W amplifier can very, very likely produce well above 2 watts of peak power, as the waveform makes its chaotic migration from + to - and back. So… good to go!
With ground-effect, the dispersion at 4 meters (a more-or-less ordinary listening distance, in a decent sized living room) nominally drops the level to 9 to 10 decibels, from the 1 meter spec. The "corner effect" (of putting your speakers right in the corner of a room) while not well regarded, again diminishes the propagation losses. Great for P.A. situations, not good for symphonic music listening.
GoatGuy
volts, watts, ohms, R and Z
Usually the sensitivity is measured as dB of SPL output at 2.83VAC input at 1 meter, on the main speaker axis in an anechoic chamber (or outdoors). Often the frequency is 400Hz. Probably the implied output for 1.2W is 90dB, so it would be 90dB/1.2W.
And the reminder that
P = E²/R (or Z = AC impedance, approximately)
P = 2.83²/8 ohms
P = 1.00 watt, nominally.
So again, SPL for 1 watt of speaker input power; at 1 meter; anechoic chamber, or simpler system such as outdoors (good call!)
Yes, lots of speaker companies have used the great outdoors for their anechoic chamber. For low frequencies, you bury the speaker flush with the surface,
and then have a good 2Pi chamber, with no low frequency cutoff.
