wharfedale diamond 9.1 mods
http://stereophile.com/standloudspeakers/1105wharfedale/
Indicates proper stands for tweeter at ear height are required.
It also indicates adding some side wall damping may help :
I've found solid vinyl (cheap) floor tiles can work well, but avoid
the types that have a vinyl layer over some indeterminate filler.
Or you could try bitumen paint :
http://www.palacechemicals.co.uk/WEBSTUFF/30-2.pdf
Reading the above article I'd be tempted to correct the bass bloom
and possibly add a subwoofer, but to do this you need a pre/power
amplifier arrangement, so it is not so easy.
🙂/sreten.
